Bobcat 52 engine thrust
Aircraft is assembled and straight...servos installed and all surfaces working properly......Fuel tank w/3 lines installed. What about engine right or left thrust? Should there be something? My engine has offset (crooked holes drilled by me). Measured to the nose of the aircraft this distance from prop tip is shorter on left than right. Make any sense?
