RCU Forums - View Single Post - HK-450GT CCPM Alloy T-Rex compatible
Old 10-09-2010 | 06:15 PM
Rob2160's Avatar
Rob2160
Default RE: HK-450GT CCPM Alloy T-Rex compatible
ORIGINAL: AKPhill
Well ok now for the hk500gt it also is a basket case so far in needing replacement
just a list, main bearings, oneway bearing, canopy bolts knight head bars, or tail support bars as each bar is in three peaces but did some checking and the heli is actualy interchangeble with align I am currently building the hk500gt thought I would share in the build
Hi,
Not sure if I follow you correctly? Are you saying these parts on the 500GT should be replaced immediately? I have the 450GT and all parts seem fine..After 50+ flights all is well. I just glued the Knighthead bars into the ends, (it actually shows to do that in the genuine Align TREX 450 Manual)
Are you using that manual?? This is the one I used for my 450GT.. http://video.align.com.tw/mpeg/manua...20New%20V2.pdf
Or are you saying these parts are difficult to replace in the event of a crash?
If/when I crash and need to replace parts I will just buy the Heli again, $29 is far less than buying even just a few genuine TREX parts.. or did I miss your point?
