RE: Gear Servo fried?
<div style="margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px; padding-top: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; background-image: initial; background-attachment: initial; background-origin: initial; background-clip: initial; background-color: rgb(255, 255, 255); font-family: Arial; font-size: 12px; ">Of the dozen or so models with retracts I have setup, all have used micro servo's as you have used, mostly JR as I am not a fan of the HS55, had too many fail for no good reason.<div>
</div><div>But</div><div>
</div><div>I have fried a couple, but not from over work, but over travel.</div><div>
</div><div>Make sure your air valve is lubed, and use the shortest arm on the servo that will give sufficient travel, and all should be good.</div><div>
</div><div>
</div></div>
