RCU Forums - View Single Post - ASM Lancaster?
Old 10-10-2010 | 03:35 AM
  #173
zob007
Default RE: ASM Lancaster?
Hi Bokis,
Congratulations for your lancaster. This electric setup looks really well, and it flies beautifully! I had a question how many AMPS do you get with these motors 4250/700 and 4S lipos and MAS 13X8X3 Props? And also wich diameter do you use for long motor cables (12 AWG?) and have you used some condensors?. I am asking this because I am actually building the Toni Nijuhuis Handley Page Halifax wich is 1/12 scale (so a little bit smaller) and I am thinking using the same setup, maybe 4250/600 could be enough actually as the plane should get 12 Kg maximum.
