ORIGINAL: 1QwkSport2.5r
...I pulled the carb barrel and needle valve assembly out and looked it over. 2 little specs of what looked like plant matter. The engine did get a little water spray the other day. Otherwise, the inside of the carb looks fine. ...
Maybe you want to fit an intake air filter? Or, are you trying to be green and burn biomass?
Regards, Richard
