RCU Forums - View Single Post - TOC 53 question
Old 10-10-2010 | 03:41 PM
rctom's Avatar
rctom
Default RE: TOC 53 question
27 degrees is close enough, it should actually be 28 but you won't see any difference and I doubt you can actually be accurate to one degree anyway.
6900 is not too bad, I've seen higher with other props but you are very close to peak HP.
Make sure you are using the muffler with the 1" outlet pipe.
TF
