RCU Forums - View Single Post - Speed Low error message
Old 10-10-2010 | 08:39 PM
H.Dale
Default Speed Low error message
Ron
I put the 44 you serviced back into my plane but it still just stops for no reason. I tried to run it three times. The first time as I throttled up it stopped with a speed low message. The second time I ran it up to full throttle but during throttling it down it stopped with the same message. The third time I ran it up to about 1/2 throttle and let it run there. After about 30 seconds it quit again with the speed low message.
Any suggestions? I have replace all of my fuel lines and didn't see any bubbles in the lines. I am using a three cell Lipo to run the ECU. I could try replacing the tank and see if that helps. I haven't done anything with the settings. The only thing I did was re-learn my transmitter.
Hal
