RE: Official HPI MT2 Thread
As long as the springs have tension on them making contact with the pilot shaft and the shoe you should be fine. If there is too much play under the shoe you can always use a small washer to shim it a little. Depending on what springs you have you might want to go a little heavier to make up for the added rpm of the engine
