RCU Forums - View Single Post - 12X Programming Help Needed
Old 10-11-2010 | 06:19 PM
F15driver's Avatar
F15driver
My Feedback: (24)
Default 12X Programming Help Needed
I want to turn off the Gyro when the gear is retracted. The gear is in Aux. 6, the gyro in Aux.4. In Mix 5 I've set the Master as Aux.6, the Slave as Aux.4. From there I'm not having any luck turning off the gyro when I retract the gear switch. I've assigned the gear switch to Aux.6 and that works fine but the instructions in the manual really are not intuitive. Any suggestions on the next programming steps needed would be most appreciated.
The Gyro is rate adjustable and I've assigned it to Aux.4 and it is adjustable on sensitivity with the knob. I've used mix 4 to mate the gyro to the nose gear in Aux.7 and that part works fine as I can adjust the sensitivity by turning the knob. Its the on-off part I'm having a problem with.
Any and all comments appreciated.
Regards,
Rob
F15driver
