RE: 12X Programming Help Needed
in the mix, select the gear switch, then set a value of zero gain for the gyro in position 1 (gear up) and your desired gain value in position 0 (gear down)
you can even assign Aux4 to the gear switch and then use ATVs (of Aux4) to do the same thing.
