RCU Forums - View Single Post - Hippo Tipo help!
Old 10-11-2010 | 10:20 PM
coloradoz's Avatar
coloradoz
My Feedback: (38)
Default RE: Hippo Tipo help!
Believe it or not, that plane will come out weighing less than the 60 size Tipo (at least in my case) - Depending on where you live, the Hanno should handle it. You can always put a BX 1.08 in it with a johnson side to rear adapter - that's what the throttle is for. I'm putting a YS91 in mine.
Look at the top of this post, Paul was kind enough to post some build instructions there. The only real critical thing that you'll need is the firewall template - I'm still working on mine, I've got a cardboard template now - and hopefully will get one that I can install soon.
