They are the same
AquaCraft
http://www3.towerhobbies.com/cgi-bin...LXMMR3&P=7 $30.20 for two of them
<pre>SPECS: Cylinder Piston Length: 33mm (1.3") 20mm (.785") Inner Diameter: 22mm (.867") n/a Outer Diameter: 25.4mm (1") 22mm (.867")</pre>
Tower 46
http://www3.towerhobbies.com/cgi-bin...LXJB07&P=7 $21.99 each
<pre>SPECS: Inner Diameter of Piston Sleeve: 22mm (.864") Outer Diameter of Piston Sleeve: 25.5mm (1.004") Height of Liner: 33mm (1.3") </pre>
