RCU Forums - View Single Post - ATJ Turbines
Thread: ATJ Turbines
Old 10-12-2010 | 09:17 AM
  #86
Bob Toilet's Avatar
Bob Toilet
Default RE: ATJ Turbines
Hi
Here are the spec`s
ATJ 170Ti Turbine engine Specifications
Dimensions 尺寸: Outer Diameter 110mm; Length: 290mm
Weight 重量 : 1750grams (including starter)
Nominal thrust @ 15C靜推力: 17KG @ 123,000rpm
Idle RPM 低速轉速: 35,000
Idle thrust @ 35,000 低速靜推力: 0.8KG
EGT 噴氣溫度範圍: 650-750 C
Fuel Consumption 油耗: @ max rpm 520 gms/min
Fuel/ oil 使用燃料: Jet -A1 or Kerosene + 5% oil (synthetic turbine engine oil)
