RCU Forums - View Single Post - Classic Pattern Plane Image-base
Old 10-12-2010 | 04:32 PM
  #373
pitstop000's Avatar
pitstop000
My Feedback: (26)
Default RE: Classic Pattern Plane Image-base
I wrote a quick program to to change transparency of the zigsaw '84 build instructions pic. Then overlaid it on the original '86 pic and captured the result.
Are there 2 models named Atlanta? That fuse is clearly different than the zigsaw model pic below which doesn't have as much rake and has the extended fwd wing fillet.
First I got to say “Wow” you got skills, definitely something I wish I possessed. [sm=thumbs_up.gif]
There are two versions of the Atlanta, the 84 and 86, The 84 has beam motor mount provisions and the 86 is setup for a conventional motor mount, no beam mount.
The differences between the planes must be subtle if any because I never noticed anything except the change in motor mounting.
Something I will have to look into when I get a chance.
That green fuse is an Atlanta, there is definitely more rake in the tail fin, might have been just how it was photographed.
It was just the tail, everything else screamed Atlanta, but Chuck made me doubt myself.[sm=confused.gif] LOL Chuck.
All settled, it’s an Atlanta! No doubt. [sm=teeth_smile.gif]
