RCU Forums - View Single Post - Making a canopy
Old 10-13-2010 | 01:35 AM
Iron Dog's Avatar
Iron Dog
Default RE: Making a canopy
ORIGINAL: Larry S
Well,
I gave it a try and only ended up ruining one large sheet of plastic. I use PETG, 020". I had enough to try three times. First one I had it in the oven where it was drooping down some, then put it over the plug with the vacuum on. I ended up with a piece that had folded in a couple of place in the front of the canopy and wasn't quite formed all the way. Next sheet I tried, I let it droop to much and it got on the tin foil in the bottom of the oven. Third and last sheet I raised the frame with the sheet higher, let it droop more then tried that. When I went to put it on the plug, it again folded is several places. Seems it will fold nice over the top of the canopy but won't around the front of it. Any ideas??? I ordered more plastic, I won't give up to easly.
Larry
Larry,
I believe I've encountered the problems you mention, and found the solution that worked for me. On my build thread, I document my attempts with a brand new vacuum forming machine I built . . .itdiscussesthe less than successful results (complete with pictures so you can see if this was the same type of problem you were experiencing), and what I learned in order to fix those problems. If you are interested, follow this link (below), andscroll downto Post #189 forthe likely solution.
http://www.rcuniverse.com/forum/m_96..._8/key_/tm.htm
I hope this may be of help. Either way, don't give up. There's a learning curve to everything in this hobby that is worthwhile. My first true success was pretty exhilarating, and madethe initialfrustrationsall worth it.
Ollie
(Oops! After I posted all this, I looked back and realized that although others posted more recently, Larry's post that I responded to is pretty ancient. Oh well, I tried.)
