RE: Ace Alpha 15 first flight problems
Sounds like the angle of attack on the wing is simply too high or the wing is loose, but 10 rubber bands ought to be enough...
How did you measure the angle of incidence, it can be tricky to get the correct angle measure on a flat bottom wing as it is highly dependent on the profile of the leading edge. I would just shim the trailing edge until it flies well.
