ORIGINAL: WhiteWolf McBride
- the bearing bolt set (317) at 101.53 looks interesting, but can it be run with ball bearings? as do the torsion mounts (311) at 60.53 (do I need them both?)
Further opinions?
Whitewolf the bearing bolts work fine with ball bearings instead of the bushes, I forgot to add to my post that I had replaced the bushes with bearings, I think the torsion mount are a bit week so that is why I replaced them
I also replaced the return rollers with the AFV set as well because I think Tamiya have let the side down with a very poor design in this area
