.40 MVVS Help
Is the engine broken in good, are you using fresh fuel with the correct amount of nitro & oil, have you tried a 9X6 apc prop, do you have the correct glow plug installed. A little more info would help to solve the problem, if infact there is one which it seems the rpm is some low.
