RCU Forums - View Single Post - Walbro carb venturi specs
Old 10-13-2010 | 11:40 AM
av8tor1977's Avatar
av8tor1977
Default RE: Walbro carb venturi specs
Check the black rubber diaphram under the stamped steel cover on the opposite side of the carb from the fuel pump. It must be very supple and flexible or the carb won't work right. If the fuel pump diaphram is stiff, the other (regulator) diapram probably is no good. You should put a rebuild kit in the carb.
AV8TOR
