RCU Forums - View Single Post - KingTech K-80
Old 10-14-2010 | 04:29 AM
  #297
Ravivos's Avatar
Ravivos
Default RE: KingTech K-80
ORIGINAL: BaldEagel
As far as I understand from Gaspar on the JetsMunt's its the ancilleries that are the problem not the FADAC, Kero start will not work at that low a voltage and three cell is too much for the valves and starter motor, this may be the case with the KingTech.
Mike
well, if the FADAC will work with 6.6V, and the valves and starter have no problem with that voltage level, and there is no kerostart on this engine...
i guess it will work but will have to have a slight tweak to the parameters (mainly glow plug value).
