RCU Forums - View Single Post - F-18E Maximum flap position
Thread
10-14-2010 | 03:43 PM
2
David Searles
My Feedback: (
49
Apr 2002
2,182
SANTA ANA, CA
RE: F-18E Maximum flap position
Pete,
That was one of the original first generation SkyMaster F-18 Super Hornet models. (painted it myself) The kit, frankly, was a piece of junk. The plane literally came apart at the seams after only a few flights. The bulkheads broke away from the fuse sides due to poor glue adhesion. (The interior was not cleaned or prepped prior to epoxying them in.) Finally the wing started to delaminate at the seams. TW did acknowledge the problems as mfg issues at the time & replaced the kit (twice), after which I finally gave up and paid for quality by buying a RTF Hornet from Tam.
As for the flap setting, it worked well for the few flights I did get and, that is very close to the full flap setting I used on my Tam Hornet, on which I put over 600 flights. The extra drag requires you to carry a bit more power on final, but that's a good thing, if you ever need to go around.
David S
Reply
Like
David Searles
View Public Profile
Send a private message to David Searles
Find More Posts by David Searles
View iTrader Profile
