RCU Forums - View Single Post - I need some help with programming transmitter
Old 10-14-2010 | 07:26 PM
Campgems
Default RE: I need some help with programming transmitter
As the other post pointed out. get the mechanical as close as you can, then end points for full shutoff and WOT. Now after the engine is running, set the expo for a linearengineresponse to the stick stck movement. Make sure your engine kill works and when it is off, full idle doesn't kill the engine. With the 9C, you will only need a couple clicks of tirm on the trottle for idle speed. Tune the engine first and then make the final tweaks wiht the programing.
Don
