RE: I need some help with programming transmitter
I got it pretty close. Moved the connections to inner sides of the servo arm and throttle barrel that helped a lot. I havent tested yet to see if engine will idle right or shut off using trim or engine kill switch. I will set up the end point adjustment on transmitter and It should be good to go.
