RCU Forums - View Single Post - I need some help with programming transmitter
Old 10-15-2010 | 10:38 AM
CGRetired's Avatar
CGRetired
Default RE: I need some help with programming transmitter
Yeah, throttle end points are the last thing to adjust after you get the linkage right. That also goes for the rest of the linkage too..elevator, rudder, and ailerons. Once set up as good as can be mechanically, then, as suggested, tweak it with end point adjustments.
CGr.
