RE: Jitter/glitching on HS-7940TH 2S lipo direct
Hi, I'll do that this evening once I rig up a battery connection for the direct connect to the receiver.
In the meantime, I've found that just experimentally adding a 330uF electrolytic cap (just happened to have one sitting around) between - and + lines of the servo extension just before the servo cures the glitching. However, putting the same cap at the smart fly end does not seem to solve anything. The servo extensions are 22GA twisted, perhaps the noise on the power leads is leaking a bit into the signal line?
