ORIGINAL: sassgrunt
I second what Rex said - the creativity you show on your build wil help me overcome problems when I get to mine. I never thought about mating the drive sprocket teeth from the Panzer III to the T-34 sprocket - that's a great idea. Did you cut the ''angle'' part off the ends of each track shoe, to make the track look more ''British''?
No, just slice off the section with the teeth, removed two and then soaked the disk in hot water for a minute to soften it up. Then, I joined it together with Krazy Glue, and simply glued it onto the t34 drive wheel. Perfect fit!
Shep
