RCU Forums - View Single Post - Glue???
Thread: Glue???
Old 10-17-2010 | 01:25 PM
Gray Beard
My Feedback: (-1)
Default RE: Glue???
It's not a big plane and would need about two ounces of thin CA and a bit of epoxy. Good old wood glue is a choice of many builders instead of the CA. I use CA on tight fitting joints of balsa and epoxy on the hardwood surfaces. CA doesn't hold hard wood very well and you want to use epoxy on the fire wall and any other high stress areas.
Great choice of plane too. I used it when I was teaching people how to build but started using the 4* 60. I'm going back to the SS again on the next build. It's a bit harder build but it's a better flying plane, not easier flying but a better plane for people wanting to learn stunt flying.
