RE: Fox 6.4 Twin Needs new CH Ignition - In Ohio
The RCexl will work, Use the 3/4 Hex plug caps.
The original CH has the small deans connector that will still work with the RCexl.
Just line up the grove in the connector to the white wire, Will plug right in and put tape or heat shrink around the connecter
Milton
