Still Have Starting Problems !!!!!!
When spinner comes off, the prop nut is not tight enough and comes loose or the motor is hydraulic locking caused by to much fuel. Spin engine over with glow plug removed to get fuel out of crank case then put plug back in and see if it locks up. ABC engines will lock at top of stroke, wind prop clock wise before turning with electric starterwill give free travel to get motor turning over.
