RCU Forums - View Single Post - Engine Weights??????
Old 04-10-2002 | 12:03 AM
Flatspin-RCU
Default engine wt
Hi all...I've always wondered why someone hasen't modified the Zenoha engines like some have done with chainsaw and weedwhip engines....everybody usually agrees they are powerful motors but weigh to much compared to the other popular brands...seem to me if one were to take a G62 and take off both of the coils and the flywheel, remove some of the lower fins, cut of the usless crankshaft that sticks out the back of the engine..(you know the one you have to cut a hole in the firewall for) and instal an electric ignition with a syncrospark then you could get the engine weight down comparable to a, say ZDZ60. I have two G62's and would voluntere one if someone could do the machining. I dont have a mill or lathe etc...oh yeah and why does CH use one of the coils with there ignitions only for the Zenohas? why not the same one as say a Brison. If this has been discused before...and it probably has could you point me to the discussion group...Thanks
Ron
