RCU Forums - View Single Post - my plane is ballooning
Old 10-18-2010 | 07:41 AM
Russmall
Default RE: my plane is ballooning
I fixed the ballooning problem on a trainer of mine by decreasing the wing incidence. It's very easy to do. Just raise the trailing edge of the wing with a popsicle stick or two until the plane behaves the way you want. If I remember correctly, I used two. Once you figure out the correct amount, you can replace the popsicle sticks with a more permanent solution. My trainer flew great afterwards. RS
