RCU Forums - View Single Post - my plane is ballooning
Old 10-18-2010 | 02:14 PM
jaka
Default RE: my plane is ballooning
Hi!
First of all you have to trim the plane at full power! At this setting it should fly straight!
Then as you probably know, all high winged trainers using a flat bottom (nearly a Clark Y airfoil) or semi symetrical airfoil, should have the engine set with a little (1-2 degrees) down trust.That's very important.
