RCU Forums - View Single Post - SAP 180 (Syssa Performance)
Old 10-18-2010 | 02:48 PM
  #1342
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: SAP 180 (Syssa Performance)
<div id="PageHeadLowerDiv"><table id="PageHeadLowerDivTable"> <tbody> <tr> <td id="idsParamImageDivColumn"> <div id="ParamImageDiv"><span id="paramimage"></span></div> </td> <td id="ItemTableDivColumn"> <div id="ItemTableDiv"> <table cellspacing="0" cellpadding="0" id="ItemTable"> <tbody> <tr> <td id="PartNumberCell"><span id="itemBoxPartNumber"><nobr>Part Number: </nobr><span id="itemBoxPartNumberWithoutLabel">5119K41</span></span></td> <td id="PricingDataCell"> <div class="priceLevelDiv"><nobr><span class="itemBoxPrice">1-49Ft.$3.79per Ft.</span></nobr></div> <div class="priceLevelDiv"><nobr><span class="itemBoxPrice">50or more$3.03per Ft.</span></nobr></div> </td> </tr> <tr> <td id="ItemAttributesCell" colspan="2"> <form name="idsFeatureValueChange" action=""> <table cellspacing="0" cellpadding="0" id="ItemAttributesTable"> <tbody> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Type</span></td> <td class="featureValueCell"><span class="itemBoxValue">High-Temperature Soft Viton&reg; Fluoroelastomer Rubber Tubing</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Material</span></td> <td class="featureValueCell"><span class="itemBoxValue">Viton&reg; Fluoroelastomer</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Shape</span></td> <td class="featureValueCell"><span class="itemBoxValue">Single Line</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Outside Dia.</span></td> <td class="featureValueCell"><span class="itemBoxValue">1/4" (.25")</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Inside Dia.</span></td> <td class="featureValueCell"><span class="itemBoxValue">1/8" (.125")</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Wall Thickness</span></td> <td class="featureValueCell"><span class="itemBoxValue">1/16" (.0625")</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Available Lengths</span></td> <td class="featureValueCell"><span class="itemBoxValue">2, 5, 10, 25, and 50 feet</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Length Note</span></td> <td class="featureValueCell"><span class="itemBoxValue">This tubing can stretch up to 2 times its length and still spring back to its original shape.</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Reinforcement</span></td> <td class="featureValueCell"><span class="itemBoxValue">Unreinforced</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Color</span></td> <td class="featureValueCell"><span class="itemBoxValue">Opaque Black</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Operating Temperature Range</span></td> <td class="featureValueCell"><span class="itemBoxValue">-15&deg; to +400&deg; F</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Performance Characteristics</span></td> <td class="featureValueCell"><span class="itemBoxValue">Ozone-Resistant, UV-Resistant</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Bend Radius</span></td> <td class="featureValueCell"><span class="itemBoxValue">Not Rated</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Durometer</span></td> <td class="featureValueCell"><span class="itemBoxValue">60A (Soft)</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Tensile Strength</span></td> <td class="featureValueCell"><span class="itemBoxValue">1,600 psi</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">For Use With</span></td> <td class="featureValueCell"><span class="itemBoxValue">Ethylene Glycol, Water</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Sterilize With</span></td> <td class="featureValueCell"><span class="itemBoxValue">Steam (autoclave)</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Specifications Met</span></td> <td class="featureValueCell"><span class="itemBoxValue">Not Rated</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Compatible Fittings</span></td> <td class="featureValueCell"><span class="itemBoxValue">Barbed</span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Chemical Compatibility Link</span></td> <td class="featureValueCell"><span class="itemBoxValue">5102KAC </span></td> </tr> <tr class="featValRow"> <td class="featureNameCell"><span class="itemBoxFeature">Caution</span></td> <td class="featureValueCell"><span class="itemBoxValue">McMaster-Carr does not guarantee chemical compatibility because many variables can affect the tubing. Ultimately, the consumer must determine chemical compatibility based on the conditions in which the product is being used.</span></td> </tr> </tbody> </table> </form> </td> </tr> </tbody> </table> </div> </td> </tr> </tbody></table></div>
