RCU Forums - View Single Post - ECHO Don't shun the 21
Old 10-18-2010 | 07:21 PM
spaceworm
Default RE: ECHO Don't shun the 21
ORIGINAL: av8tor1977
Oh the prop adapter doesn't move once installed. I use Loctite on the threads, and then with the set screw besides, it doesn't budge. Often times when I take them off I have to heat them to get them to come loose.
This particular engine was set up to run Gas/Glow, and it doesn't use a Hall sensor. When I use electronic ignition, I make up an adjustable collar that goes around the small diameter of the prop adapter. The magnet goes in the collar, and the timing adjustment is made there. Works fine, and has done so for many years.
AV8TOR
I have one that I want to try gas/glow on. What fuel mix and oil mix have you had good luck with. Of course, what plug, and start only or full time glow? Thank you very much. Do you make prop adapters for other people, I need one?
Regards,
Richard
