RE: am I LoCo?
Their 8oz std fits in some tight spaces if you have the length, it's 2" OD. The flattish "CG" tank will actually entirely hide in the depth of a Demon wing if you move the forward spar, so turned on its side it is a good candidate when you have depth but not width [ i.e. where you touch bottom but leave the sides alone.. ;-) ]. Mind you at just under 6oz it will also get sucked dry in less than three minutes at full tilt.
