RCU Forums - View Single Post - Programming flaperons for a Pulse XT40
Old 10-19-2010 | 06:49 PM
rivas8409
Default RE: Programming flaperons for a Pulse XT40
Thanks for the input Redback, but I've still got the ailerons connected into the aileron port through a Y-Harness. I guess I could disconnect the y-harness and use the individual aileron servo leads connected directly to the reciever but with the Pulse's design (access hatch is underneath the fuselage and can only get to by taking off the wing) it wold make it a little difficult to connect the ailerons every every time I transported the model to the field. I'd also rather repeatedly connect and disconnect the ailerons at the Y-harness since the Y is cheaper to replace than the reciever.
