RE: High intensity flash unit.help
No, you need a new flash unit.If you plan on using the original circuit it came from. there are ways you use an LED for flash but that is a different set up al together. the High tension flash units use VERY HIGH voltages like the flash on a camera. It can be in the thousands of volts.
