BH Models AT-6 83" WS
Question concerning CG balance. When the landing gear is in the up position it is well forward of the CG. When the gear is lowered it is still forward of the CG. In what position should the gear be located, up or down? Think about your answer, because on most warbirds, when the gear is lowered it is aft of the CG. In this configuration you balance the airframe with the gear retracted.
