ORIGINAL: Vertical3-D
here are the best pics I could get without removing the engine...one of the bottom and one of the top of the carbs...the low end are in the aluminum throttle arm pieces that are on the barrels, highs seem fairly far out at 5 turns, almost off the detents, but those I can figure out no problem, just would like to get the lows somewhere close before trying to start it again, rather than blow raw fuel all over everything like last time I fired it up...
Is that a crack in the engine mount in the left picture, or just the shear marks from the stamping?
Best regards, Richard
