RCU Forums - View Single Post - esc selection help
Old 10-21-2010 | 11:01 AM
cat samich
Default RE: esc selection help
ORIGINAL: NobodyFamous
Husky, Thank you for shedding some light on the subject with FACTS.<div>
</div><div>Cat Sandwitch. . . J/K back on topic. The Leopard 4082 says it has a PEAK wattage over 3500 watts, at 3500 watts and 22.2V that is 158 Amps.</div><div>
</div><div>That number will go up if you drop the voltage, but only if you are demanding that power from the motor. (by propping up)</div><div>
</div><div>So asuming you set up your boat and choose the best prop running on 6s, you should go with an ESC over 160A. If it where me, I would go with a 180A ESC. That should give you lots of head room.</div><div>
</div><div>The constant rated power output from that motor on 6s would be closer to 90amps, but can peak up to 158amps ''or more'' as they state.</div><div>
</div><div>With that motor on a 180a ESC and 6s you will have a cool running super efficient boat.</div>
thank you sir, finally a straight answer lol. my biggest problem is that i dont know the formulas to calculate all the numbers to figure out what the motor will pull. im going to give myself tons of head room and pick up an aquastar 240 or a swordfish 240
thanks for the help guys
