After taping the template together I grabbed the trusty ol' Elmers spray on glue and applied a small amount in 4 spots and attached it to a 12x48" piece of 1/8" ply. I cut the 1st piece out on the bandsaw and sanded to the final shape with my bench mounted disc sander. Once I was done with that I cut out the other side making it slightly larger than the 1st and then I dabbed hot melt in 4 spots and stuck the sides together. I did this so that I can just use the piloted laminate trim bit and get the 2 sides to match - mistake for mistake
. As you can see, I didn't have the bit quite high enough and I missed a bit. Not too much of a problem, I just trimmed the wee bit off with a razor blade.
