RCU Forums - View Single Post - Problems with Nine Eagles Xtra 300
Old 10-21-2010 | 04:35 PM
kirtash92
Default Problems with Nine Eagles Xtra 300
<div id="post_message_16348691">Good evening guys,
I recently bought two Nine Eagles Xtra 300 planes and they don't work properly.
The first one doesn't receive the signal from the transmitter. When I plug in the battery, the green light on the receiver turns on, but the red one does not. The plane does not respond to any signal from the transmitter.
The second plane responds to the transmitter, but the aileron doesn&rsquo;t work. I have also tried the aileron from the first plane and it does not work either. In this plane, both the green and red lights turn on, and the throttle, rudder and elevator work fine.
The batteries were fully charged and I turned on the controllers before I plugged the batteries on the planes.
I have contacted my supplier (herohobbyshop from ebay.de) and have not obtained any technical solution.
I was hoping to get some support from you guys, specially on the calibration of the first plane.
Thanks in advance.</div><! / message >
