RCU Forums - View Single Post - Charging 6.0v 1400 mAh NiMH Normal
Old 10-21-2010 | 07:10 PM
Mikecam
Default RE: Charging 6.0v 1400 mAh NiMH Normal
It will tell you the capacity of the battery. How much you put in is not the same as doing a discharge cycle. Do a discharge and see what you get out of the pack, you will find it will be a lot less then the 1759 ma/h you put in. Likely a lot less. Let us know.
