RE: Sig Smith Miniplane build
I corrected my error in post 545.
I also found the engine thrust angles to depend on your engine/prop combination. Never tried a four stroke in mine so I have no idea how they act. But a little down thrust and right thrust in the 1 to 2ish degrees range will help. Then you can adjust from there.
