RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 10-23-2010 | 04:40 AM
  #1261
a1pcfixer's Avatar
a1pcfixer
My Feedback: (7)
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
This is good for all the larger sticks;
Create a block of wood to put between the fuse & the L-G (1/2" or thicker)
Make it about 3/8" longer in front of & behind L-G. Harden the groove the L-G sits in, then when finished, drill some lightening holes in the L-G groove.
For just a few ounces weight you'll be able to increase your prop-to-ground clearance.
