RE: KMP Stuka-build details
Things are going fine so far. Been working on getting the cowling mounted and on the throttle/choke mechanics. I want to built an access hatch on the top forward part of the fuse, behind the firewall. It will be under the cowl but will give me access to that whole "behind the firewall" area. I can use that area for batteries, ignition modules, ballast ... whatever. Maybe I will still use the pull pull but replace the thin wire cable with kevlar. I want to get the throttle servo mounted and connected, the fuel tank plumbed and installed, and the ignition module mounted. Then I will move on to the wings.
Charles
