RCU Forums - View Single Post - WING VOLUME VERSES SURFACE AREA
Old 10-23-2010 | 08:15 PM
Campgems
Default RE: WING VOLUME VERSES SURFACE AREA
ORIGINAL: da Rock
You're asking for a comparison between wing loading and the "wing volume" theory, right?
Both are simply formulas that produce numbers that are then associated with subjectively based predictions.
Both work perfectly well for the purpose of predicting the results of different wing loadings. They're only as good as the subjective predictions. Which in both cases are good enough.
SWAG
Scientific Wild A$* Guess. I've done some of those.
Don
