RE: Saito shuts off
First my apology for posting in the wrong area. Not good at this and will try to delete it.
The low speed screw is as recommended by the manual, counterclockwise until even with the hub. The high speed needle valve is out about 3.5 turns. Lots of smoke. Solid fuel draw. Valve tappets set at .003 - .004. I was surprised at the RPM also since a lot of my flying buddies can't even come that close with theirs using the same prop. Usually 9500 or lower.
It's a used motor.
So now a suggestion on how to delete this entry from this area and move it to the proper place and how to find it.
