RE: Saito shuts off
Does the smoke out the tail pipe stay the same or reduce as the run progresses ? Also try running it at 3/4 throttle instead of full and see if the same thing happen. If it does try a 12x7 prop. How used is this engine, can you post a pic. Did you check for carbon build up.
