RCU Forums - View Single Post - Any JR guys using this?
Old 10-24-2010 | 11:41 PM
rickj202
My Feedback: (37)
Default RE: Any JR guys using this?
ORIGINAL: Ruizmilton
I tried my FASST/JR XP9303 module today for the first time in a Jet (brand new C-ARF Flash/JC Super Eagle) I worked perfectly with no issues, I had tried it before on small electrics, but not on a Jet. I was able to get low power range checks at over 300ft with no failsafes (tried it more than once just to be sure) the good thing about the FASST module is that it will also work on the 12X using all 12 channels. I must confess I was scared about using it in a jet, but it worked flawlessly.
My plan is to eventually use a Weatronics 2.4 module for my jets, mostly because of the bells & wistles, not the RF link(when you think about how much it will cost to have an Eagletree Pro telemetry system vs Weatronics having it all integrated, it makes a lot of sense to go with Wea). The FASST system I will use for everything else, yet, seems the FASST module will work just as good for jets.
Ruizmilton,
So you used the module in a JR 12X? Which module did you use? The Hobbico does not mention the 12X.
Rick
